Mercruiser 420's single plane or dual plane?? >
Old 05-13-2012 | 11:12 AM
  #61
I'd definitly double check the merlin part #'s, if possible. The #030620 was a 320CC intake runner, iron head. The 030630, was a 345cc intake runner iron head.
Was there a "b" or "C" after the "1-043" stamping? The B would be 320cc, C would be 345.
MILD THUNDER is offline
Old 05-13-2012 | 03:36 PM
  #62
Full Force's Avatar
The only numbers on the heads were the ones I posted, no 6 digit numbers anywhere, if they were there I would have known for sure what they are...
Full Force is offline
Old 05-13-2012 | 04:47 PM
  #63
Ok. Was just checking, tryin to help save ya some work. Seems like you've got it figured out.
Old 05-13-2012 | 04:53 PM
  #64
Full Force's Avatar
Thx, thats the part that sucks, there is no true way to tell on these unless I CC em... I took a guess back in the day... was wrong most like;ly..oops
Old 05-16-2012 | 11:22 AM
  #65
Originally Posted by MILD THUNDER
Jeremy, you said the imco manifolds were worth 7hp. Compared to what other manifolds?
Sorry i forgot to post back.
My manifolds are Kodiak Alum with an IMCO riser. when i had them built in 09 we used a set of IMCO powerflows.
Car Biz is offline
Old 05-16-2012 | 11:29 AM
  #66
Originally Posted by Full Force
ya... Dean told me easy 510-520 hp if we do it right.. just with heads and cam change..
This is the reason i had mine dynoed again. Just to see if any more power was left on the table. I found out i need to port my heads and do a cam change and that is what would be expected out of mine.
Car Biz is offline
Old 07-02-2012 | 09:44 PM
  #67
Full Force's Avatar
Ok, so I put same engines in my new ride (35 Mistress) that is a ton heavier, only lost 2 mph and gained 3-400 rpm with same props...I saw 63mpoh@4900 and thats aboput where these cams are done... I am thinking with custom roller cams I can grab a few more hp out of em...
