Mercury Racing 600 SCI Fuel Consumption
http://mercuryracing.com/sterndrives/hp600sci/specs.php
Your HP divides by 12 will give you a good estimate. 750hp/12=62.5 gallons per hour at WOT. That is per engine.
I have a single 600 sci stage 2 whipple. I am very happy with it and have had it for two years. I guess I should say happy except for fuel consumption. I don't have a formula but here is a good one. Keep your wallet handy!
Have heard of issues spinning stock valvetrain too high, so re-geared to keep just above the stock 5400 limit. The last 25 or so hp achieved by the extra rpm is not worth the loss in reliability.
Watch your valve train like a hawk! Mercury never intended these engines to run 6,000 rpm. If they're stock 600SCi heads, they were rated at 5,200 max. At 6,000 you will frequently replace rockers, springs and valves -- if you are lucky. Pistons, rods, cranks and cylinder blocks are likely, if your engine swallows a valve.
