525 efi queston >
525 efi queston
525 efi queston
Old 05-12-2012 | 06:17 AM
Default 525 efi queston
Was wondering if anyone on here swaped a 502 mpi injection system out to a 525 fuel injection using the mefi computer not the motorola computer that is normally used on a 525 if so i would like some info. on how you did it thanks for any help
33-outlaw is offline
Old 05-14-2012 | 03:05 PM
ttt
Old 05-14-2012 | 06:23 PM
What year 502 MPI are you working with? Is it VST or Cool_Fuel?
tunertech is offline
Old 05-14-2012 | 07:41 PM
articfriends's Avatar
I know at one point Crockett was converting 555 motors to mefi 4 so they could be tuned after mods, shouldn't be no reason you couldn't make it work,probably won't work as precise though as the original though. I installed a mefi4 and harness on a Pontiac 455 so anything can be done if you put enough effort into it, Smitty
articfriends is offline
Old 05-14-2012 | 08:06 PM
the motor is a 2000 gen 6 502 mag mefi 4 with cool fuel
Old 05-14-2012 | 10:31 PM
you can make the conversion but it's not a plug-n-play conversion.
Old 05-15-2012 | 04:22 AM
thanks for your input i will most likely start looking for a wiring harness and computer to make thinks a little easyer.
