Green tag borg warner >
Old 05-16-2012 | 12:11 PM
Default Green tag borg warner
Couple quick transmission questions.
1. What size bolt is needed for the side mounting bosses?
2. When converting from a trs plug in to a #V driveline style, what does everyone do for the shifting linkage, no provisions on the huber 1350's for linkage?
rob vanharten is offline
Old 05-16-2012 | 04:55 PM
RMPRam's Avatar
I used an alum. bracket that had tabs, if I remember correctly, that attached to 2 bellhousing bolts and a flat area in the center, between the tabs, that the Morse cable adapter that held the end of the shifting cable, bolted to. I may have 2 brackets, I will look if you are interested.
Gary
612-247-7081
RMPRam is offline
Old 05-16-2012 | 05:46 PM
Thanks Gary, I figured I would have to fab something up to mimic the trs setup. If you have a second to look that would be great.
Old 05-17-2012 | 05:26 PM
RMPRam's Avatar
Sorry, Rob. I did a quick scan of all the transmission parts and the only shift cable brackets that I have are a pair for #6 plug-in transmissions.
RMPRam is offline
Old 05-17-2012 | 09:12 PM
Biggus's Avatar
Konrad makes a nice shift bracket for the BW trans. mounts right up to the boss on the case. Call Pete in parts if interested. 715-386-4203
Biggus is offline
Old 05-18-2012 | 08:28 AM
Thanks for looking, I appreciate it!!!
Old 05-18-2012 | 08:43 AM
Just got off the phone with Pete, thanks for the tip!!!
Old 05-18-2012 | 09:45 AM
Biggus's Avatar
Glad I could help!
Kurt
Biggus is offline
Old 05-18-2012 | 10:13 AM
tcelano's Avatar
The side bolt holes are 7/16"-14
tcelano is offline
Old 05-18-2012 | 12:43 PM
Awesome thanks!
