Oil filter bypass
After wiping a lobe off of my camshaft I realized that a lot of material went through the motor is it good practice to block off the oil filter bypass or will I be asking for problems
Originally Posted by aafed
(Post 3689087)
Yes - good idea to block it off - I used a frost plug.
Originally Posted by PayCheck
(Post 3689269)
Don't forget to change the oil cooler also. I have seen metal everywhere. In the piston skirts, lifters, coolers, oil cooler hoses, valve guides, fuel pumps (MarkIV).
Sorry to hear about your problem, most of us have been there one time or another.:eek: |
unfortinatly,flat tappit cam cores are being imported from china,and are junk,i highly recommend going with a hyd roller if it is in the budget.im rebuilding a merc 370 hp rebuild for someone now and im worried about the new flat tappet cam,even with proper break in they still go flat.if you do use a flat tappet cam,make sure you use a good break in oil and add zddp to it.
Originally Posted by mike tkach
(Post 3689396)
Originally Posted by 1BIGJIM
(Post 3689312)
(Post 3689478)
I thought the cooler was after the filter if this is the case what is the possibility of debris getting in their?
At minimum put the filter after the cooler if it is not. |
fixx
(Post 3689396)
Originally Posted by mrfixxall
(Post 3689515)
mike,,i have had great luck with crower cam saver lifters,crower grinds a flat spot on the lower half of the lifter,when it spins it dumps oil on the camshaft..
(Post 3689645)
fixx,i did not know about those,il look into it,thanks for the tip.
I think you may be pleasantly surprised how they work. |
fixx
(Post 3689645)
i use the 66000rx3,this lifter has the heavy cuty spap ring to hold the plunger in instead of a square piece of spring wire..55-58 rockwell hardened..jobber from crower is like 90 bucks they also have a better lifter,differant material and 63-64 rockwell hardened with mirror polished surface where the cam rides..this one is 66000p3 and jobber is around 182.00 best price is from crower unless joe knows a better place to get them :lolhit: two names,,one was cam saver and now they call them hi lube lifters.. ps.you will loose about 5-7 psi of oil pressure,,shim the spring in the oil pump with a tiny washer to make up for it.. |
(Post 3690088)
Crower part #
oil filter has bypass valve, so some junk will get by and can't guarantee cleaning will remove. every engine company has tried to clean oil coolers every way; hot, cold, forward and backward. acid and ultrasonic, still find particles that have or could killed new engine. cheapest option replace it.
| All times are GMT -5. The time now is 09:55 AM. |
