Freeze damage?
Yeah, local shop did the winterize. It is a great place, with a great rep, nice guy who said he would make it right. I just want to make sure if we just put some plugs back in, that I truly dodged a bullet.
You can be sure I will run the hell out of it to find out.....
usually bbc crack from a water passge to lifter valley under the head,cant see but,,,,,,run it to operating temp on hose,itll show sings of water quick..also see if oil level is high on dipstick....maybe pull pan bolt an see if yu get water out 1st....
You'll either see water in the bilge or in the oil. Will happen quick too. On the hose in the drive way should show you what you have.
I've replaced several motors for customers up north yrs back due to this.
Also had twin inboards in my personal cruiser (also yrs back) do it to me. They were small block Chryslers though and popped the ones in the back of the block, in front of the bell housings. Was very lucky and that was only damage too.
Also lost a car motor when up north too. Same thing though. I knew instantly and was no disguising it.
happpen to me 2 years ago in my 502 only problem it was one behind the block inside the bellhousing so the motor had to be pulled ,replaced it and all was good no other damage alot of work for a 10 dollar part but i counted my blessings that it wasnt a cracked block and i was able to repaint the bilge while the motor was out
