plug heat range >
plug heat range
plug heat range
Old 05-22-2012 | 09:21 PM
Default plug heat range
this question is for you guys with supercharged engines,what brand of plug do you like and what heat range are you running.
mike tkach is offline
Old 05-22-2012 | 09:22 PM
NGK V8's
bigfarmer is offline
Old 05-22-2012 | 09:30 PM
Non-projected tip NGK -9's.
WETTE VETTE is offline
Old 05-23-2012 | 07:13 AM
only 2 guys know what plugs you use?
Old 05-23-2012 | 08:03 AM
MER Performance's Avatar
For a gasket style plug,forced or natural induction. I always try to use a NGK R5672A-8 this is either for alum. or cast iron heads. To use a non projected plug is going to shroud the spark in the combustion chamber. I believe; you need enough heat range on the ceramic to control plug fowling at idle, but not at off idle or higher rpms. A/F ratio needs to be correct in order to prevent fowling, detonation and pre ignition. This also pertains to compression ratio, timing, fuel octane # and what is the water temp when idling. If a piston dome interferes with the plug electrode you would either index it or use a non projected plug. I know in the past Merc used like a MR 43, I believe this was maybe due to fuel back then and now we are needing the engines to burn cleaner. Maybe a little to much info. Hope this helps.
MER Performance is offline
Old 05-23-2012 | 08:48 AM
obnoxus's Avatar
Charter Member #1171
Ngk br8
a/c 41t
But those were no where near the HP motors that I know your asking about !!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
