High Oil Pressure >
High Oil Pressure
High Oil Pressure
Old 05-23-2012 | 03:42 PM
Default High Oil Pressure
I'm trying to figure out what would cause high oil pressure? it idles around 60psi and goes up to 90 psi when i get on it. This happened after I got the boat back from having a large stereo/inverter installed and a few of my gauges do flicker and act up, however i think the high oil pressure is correct be cause i can see oil being pushed up the clear oil tube that injects into the flame arrestor.
Any thoughts on where to start?
FREAKY FAST is offline
Old 05-23-2012 | 04:40 PM
Im assuming it has changed from what it was? Is it an electric gauge? If it is i would try putting a mechanical gauge on it and see if somehow when they wired up your stereo it jacked up something with your gauges.
MASCH is offline
