Twin turbo setup >
Twin turbo setup
Twin turbo setup
Old 05-26-2012 | 02:00 PM
Default Twin turbo setup
looking for any feedback on a PFM twin turbo setup.
Anybody ran one before? and if so what kind of resalts did you get?
This is a BBC setup with ton of aftermarket goodies !!
Hardin Marine headers 950 cfm blow through carb MSD boost control ignition with rev limit & boost retard.
It does have an inner cooler setup boat is setup with exhaust gages, boost geage, fuel pressure, water pressure, water temp, oil temp, trans temp, oil pressure ect ect.
I do see knock sensors in the canfield heads & block so it seems to have several safety features
FORMULAfast is offline
Old 05-26-2012 | 10:21 PM
Scarab28's Avatar
I ran a PFM setup on a jet boat for years. Only diff is it was a draw thu setup. Basically a clone of the old Gale banks turbos. Figure around 650 hp, 8 - 10 lbs boost, and tons of torque. You'll need inconnel exhaust valves and low compression motor.
Scarab28 is offline
Old 05-29-2012 | 09:01 PM
cool thanks
