mild 454 upgrades? >
mild 454 upgrades?
mild 454 upgrades?
Old 06-02-2012 | 12:14 PM
i started with a 98 model 330 with l29 heads and added gil hp500 exhaust, edelbrock air gap dual plane intake, pro comp 750 mech secondaries carb, crane 731 cam, isky springs, 10 degree locks, used stock roller lifters, scorpion roller rockers, holley blue pump, upgraded -8 fuel lines, big water seperator, huge oil cooler, oil thermostat, k&n flame arestor, used the thunderbolt igntion flyweel belhousing and coupler that came with the pile of parts that came with my boat. i put that all together for 3500 bucks and that included buying the used short block, i am on season 3 with it. has great power but i cant get it over 5000rpm yet, far more power than stock and it sounds great. my plan has been build it more more power with all of the good parts so when it comes time to drop my stroker motor in everything is already set up for it.
regalman4925 is offline
Old 06-02-2012 | 08:30 PM
Originally Posted by Itsallgood995
I did the above w/ 496 manifolds, ported vortec heads, air gap & 454/502HO cam. Went from stock 3 blade 21p prop to a 23p 4 blade.
So im guessing had you kept the same 21p 3 blade, you probably would have gained about 400-600RPM? Sounds like maybe 5-6mph gain?
MILD THUNDER is offline
Old 06-02-2012 | 08:35 PM
Originally Posted by cp5899
Hopefully the flat tops will work in my favor over the lower compression dish pistons.
Flat tops and a 119cc chamber, should be around 8.2-8.4 or so.
Old 06-02-2012 | 08:54 PM
Low enough for a blower. Sounds good. Lol
cp5899 is offline
Old 06-03-2012 | 01:12 AM
Pretty much, don’t have pre gps speeds to say exactly but that’s atleast a fair statement. Its been a great set up for nearly 300hrs but the need for speed has hit again. You could stroke the short block & reuse the top end so I don’t necessarily agree it’s a waste of money build off these 330 based motors. You gotta start somewhere.
Itsallgood995 is offline
Old 06-05-2012 | 03:42 PM
found this kit online anyones thoughts? http://www.jegs.com/i/Edelbrock/350/61459K/10002/-1
prerunner404 is offline
Old 06-05-2012 | 04:52 PM
Wink
I know you're attracted to that kit because its realitiivly inexpensive and it says MARINE. Truth is if you're gonna do the top end right, talk to Bob Madera @ Marine Kinetics here on OSO about his recommendations for heads, cam, etc.
If you're gonna spend $2600, spend a little more, do it right and get better results.
My opinion.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 06-05-2012 | 05:17 PM
the bob madera cam may be a bit better but that is a attractive kit for the money... i have been looking at those heads for awhile
Old 06-05-2012 | 05:52 PM
the performer rpm cam isn't a marine grind. and the intake doesn't have the bronze insert for the water passage. only marine part is the carb, and that may just be a word typed after RPM...
dereknkathy is offline
