454 Mag stroked to 496 w/ProcCharge what carb >
Old 06-03-2012 | 09:45 AM
egbolt's Avatar
Default 454 Mag stroked to 496 w/ProcCharge what carb
Winter project trying to get finished buliding 454 stroke to 496 run 8.7:1 comp, Bob Madara cam, 781 heads with work, inconel valves port polish, Question is what size carb. I have been told to go smaller blow thru like 450 cfm I currnetly have 850 but told to much carb and would not work.(Run Lean) My thinking is i need more since pushing air 3.5 boost. M3sc procharger
Any thoughts, sorry if I left any info out,
egbolt is offline
Old 06-03-2012 | 09:51 AM
im thinking around 750 cfm,call quickfuel carbs,they make a great carb and have experiance with blow threw setups.
mike tkach is offline
Old 06-03-2012 | 03:32 PM
Default fixx
+1, 750 cfm should be perfect,,if you want a B i t c h i n carberator for your set up and not have to worrie about the temp changes go with a c&s specialties aerosol carberator...they are real responsive too!
http://www.candsspecialties.com/stor...lbillets2.html
FIXX is offline
Old 06-03-2012 | 04:17 PM
rmbuilder's Avatar
MarineKinetics
Eric,
Did Vrbancic Bros. Racing (AKA The Carb Shop) provide you with that recommendation?
Regards,
Bob
rmbuilder is offline
Old 06-03-2012 | 07:06 PM
egbolt's Avatar
Check private message
egbolt is offline
Old 06-03-2012 | 07:09 PM
egbolt's Avatar
Default Bob check private message
egbolt is offline
Old 06-03-2012 | 07:17 PM
egbolt's Avatar
Also running big pc intercooler box 504 I believe
egbolt is offline
Old 06-03-2012 | 07:22 PM
Default fixx
if you deside to go wit hsomeone elses recomendation at leaste have them put auunlar boosters in tghe carb..with the c&s carb theirs vary little restriction unlike a regular booster type carberator..
FIXX is offline
Old 06-04-2012 | 06:02 AM
I'm running 509 w/MSC3 used a 950 from prosystems, was spot on out of the box...patrick is who you need to talk to...Rob
ezstriper is offline
