is this good water press. psi? >
Old 06-04-2012 | 04:41 PM
Default is this good water press. psi?
at 2200 rpm reading 5 psi.
at 3000 rpm to 4900 rpm 10 to 12 psi
on a big block mercrusier with blowers
mookster is offline
Old 06-04-2012 | 08:13 PM
jbraun2828's Avatar
yes, those are good numbers
jbraun2828 is offline
Old 06-04-2012 | 08:23 PM
thanks
mookster is offline
Old 06-05-2012 | 07:21 AM
ttt
mookster is offline
Old 06-05-2012 | 07:44 AM
My 496 is 4 at idle. At 2000 RPM it is appx 15 psi and at 3000+ it is around 25-30. We are talking water pump pressure here for the raw water pump, right?
Redhook98 is offline
Old 06-05-2012 | 08:18 PM
taking readings at the side of the block. until i get a few fittings to take readings from my intakes
mookster is offline
Old 06-06-2012 | 07:35 AM
Seems low to me but my experience is limited. I thought you'd want to see 20-25 with raw water cooling & 35ish with closed cooling.
thirdchildhood is offline
Old 06-06-2012 | 07:45 AM
That is right where my 575sci's run, never breaks 150 degrees.
4bus is offline
Old 06-06-2012 | 08:29 AM
+1
BenPerfected is offline
Old 06-06-2012 | 08:33 AM
GRH
You don't wan't to see over 30lbs.....
GRH is offline
