GM 3.0 L4 Piston ring difference >
Old 06-10-2012 | 03:46 PM
Default GM 3.0 L4 Piston ring difference
I am in the need for some pistonrings for a GM 3.0L L4.
It is a Volvo 140 from 1995/1996. it is exactly the same engine as the 3.0LX from Mercruiser.
Starting at about 1990 till now the part# for the mercruiser rings is 39-17464. The top and second ring on the piston have about the same inner and outer diameter(width). But these new rings(17464) are different. The top ring has a larger inner diameter(less width about 1mm) than the old one, so I have a lot of back clearence.
I checked the pistons with some of a old 1996 Mercruiser 3.0LX, and they are exactly the same flat top pistons.
So if I order new rings for this 3.0LX am getting something different than it was fitted from the factory.
It doesn't feel right to fit them.
Please any advise.....
Ford Capri is offline
