bennet tabs/ K-plates >
Old 06-10-2012 | 10:43 PM
Default bennet tabs/ K-plates
pros? cons? what are the differance what would i want on my boat? looking at a 27ft fourmula......lakes and rivers....
any info would be great
sorry new to the game just trying to learn
LFDE18 is offline
Old 06-11-2012 | 08:41 AM
hammerdown500's Avatar
K plains are better. 280 series. But the bennett 12x16 sport tabs shouldf do the job as well
hammerdown500 is offline
Old 06-11-2012 | 10:47 AM
i won't say the biggest diff is price, but it is a big diff. rule of thumb, if you need hydraulic steering you need k-planes or equivalent. biggest bennets are not equivalent...
dereknkathy is offline
Old 06-14-2012 | 03:44 PM
IMHO, if you're out in bigger water, the Bennet product will not tolerate the abuse. I had them on my Baja. Every time I'd land a$$ first on a wave, I'd blow up the rams. I got K Planes, no more problems. They were a spendy upgrade though, that's for sure. Check out the boat first. I'd say if you don't need tabs to operate the boat, don't even sweat the Bennets. I know lotsa people that don't even use their tabs / K planes.
twinskrewd is offline
Old 06-14-2012 | 05:56 PM
Too Stroked's Avatar
Generally speaking, the heavier / longer the boat and / or the rougher the water, the heavier duty the tab required. For the kind of water you're talking about on the hull you mentioned, you can probably get away with Bennett Sport Tabs with the dual cylinders. Any bigger of a hull in rougher water though, you'd be better off with K-Planes. They're next to indestructable. (And a lost costlier too.)
Too Stroked is offline
Old 06-14-2012 | 07:06 PM
Single or dual rams and how heavy is your boat!
jrdonnellyjr is offline
Old 06-14-2012 | 08:08 PM
The problem with Bennett tabs is that they are sooooooo slow. The other problem is one is always faster than the other. The rams are made of plastic and can not take much abuse. I removed mine and installed Merc 280s. Jeff Wurl
jwurl is offline
Old 06-14-2012 | 09:07 PM
IMO definitely worth the $$ to upgrade if you run in rough water. I went from dual ram Bennett's to 280S K-Planes on my 292 (basically a 27 boat) and it was worth every penny.
4mulafastech is offline
Old 06-15-2012 | 06:51 AM
I am going from a dual ram bennett sport tabs on a 271 to a pair of custom fabricated tabs still using the bennett cylinders the other thing I changed is adding a second bennett pump only to help with time it takes for tabs to go up and down
353Formula is offline
Old 06-15-2012 | 10:08 AM
The other end of the speed spectrum is the Lenco electric tabs. They move so fast they can scare you.
