Mobil 1 oil? >
Mobil 1 oil?
Mobil 1 oil?
Old 06-10-2012 | 11:48 PM
Default Mobil 1 oil?
Anybody know for sure if Mobil 1 15w50 oil has the zinc additive needed for flat tappet camshafts?
JD33 is offline
Old 06-11-2012 | 12:01 AM
Default fixx
i use it on my flat tappet cam,,,no issues but i also put a qt of lucas oil additive...i also use M1 in my 92 sub 454 with flat tappet cam..10w30 and 462000 k and still purs like a kitten.all oe and nothing major has been done to the engine except basic maintaice..knock on wood..
FIXX is offline
Old 06-11-2012 | 07:48 AM
Mobil website answers this question - the zinc / phos levels have not changed in 15W50 - still 1200+ ppm, plenty for a flat tappet. I use M1 15W50, and after use my zinc / phos levels are never under 1300 ppm.
apollard is offline
Old 06-11-2012 | 10:06 PM
OK, Thanks for the info.
JD33 is offline
Old 06-12-2012 | 09:03 AM
MOP
Lightbulb
Motor cycle oils still have zinc, I would use either the Harley or Spectro oil. I have been using the Spectro for a few changes it stays unbelievably clean, also shows very little pressure drop at higher temps.
MOP is offline
