Stainless Steel exhaust tips >
Old 06-19-2012 | 11:03 AM
khubard's Avatar
Default Stainless Steel exhaust tips
Hey guys, I need some advice on maintaining stainless steel exhaust tips. I wet sanded the tips and got all polished up looking very nice. Took the boat out and after one run down the lake they were stained and already looking discolored. I cleaned them back up and used metal polished thinking this would protect from the water and exhaust heat. No luck. Cleaned them up again and tried using wax to protect them. Still having the same problem. Is there anything I can put on them to protect the finish?
khubard is offline
Old 06-19-2012 | 11:21 AM
I take a rag with a little muriatic acid on it and wipe around the tips, takes about a minute and lasts pretty much all season. Are the tips 316 stainless? Shouldn't discolor that quick I wouldn't think.
Mr Maine is offline
Old 06-19-2012 | 11:44 AM
khubard's Avatar
I assume they are 316. I will try that. I read a article on line about using vinegar. Any input on that?
khubard is offline
Old 06-19-2012 | 11:51 AM
The acid will take off that bit of rust/soot colored stain around the rim but won't equal the manual polishing etc. I suppose vingegar is a weak acid and will probably work but may take longer or not come out as good as muriatic.
Mr Maine is offline
Old 06-19-2012 | 11:55 AM
Lime away and a magic eraser always seem to clean mine up after a day on the river. Haven't found a way to keep them clean for a long period.
Wasted Income is offline
Old 06-19-2012 | 04:24 PM
what about clearcoating them? i don't think they get that hot.
dereknkathy is offline
Old 06-19-2012 | 04:45 PM
I use vinegar after every trip. If it gets real bad you can use rubbing compound or stainless cleaner.
jeffswav is offline
Old 06-19-2012 | 06:32 PM
Just spray some CLR on it. The haze is the calcium and minerals in the water left behind after evaporation. Doesn't matter what you coat them with the minerals will be left behind.
CLR removes that stuff in short order.
Trash is offline
