Garmin fuel flow sensor vs SmartCraft/MercMonitor vs ??? >
Old 06-20-2012 | 02:50 PM
tlr
Default Garmin fuel flow sensor vs SmartCraft/MercMonitor vs ???
I'd like to add a fuel flow display to my 2003 Mercruiser 496 MAG HO.
I have a GPSMAP 546 chartplotter, so I think I could get the Garmin GFS-10 fuel flow sensor (https://buy.garmin.com/shop/shop.do?pID=11561) for $200
Alternatively I could get a SmartCraft gauge or NMEA 2000 converter like the MercMonitor, but it's quite a lot more expensive, but then I'd have a dedicated gauge and more engine data available.
Does anyone have any experience with either of these?
Thanks.
tlr is offline
Old 06-20-2012 | 03:52 PM
Mbam's Avatar
Offshoreonly Advertiser
I think you are better of with the mercmonitor. The engine knows how much fuel it is using.
Mbam is offline
Old 06-21-2012 | 06:33 AM
I went with the Smartcraft System Monitor. So far it has been very accurate and it gives me important data like water pump PSI, GPH, Gallons used, temp (which seems to be more accurate then my analog gauge), etc. Found it on Ebay for $90 with a cable and the monitor (used obviously).
Redhook98 is offline
Old 06-21-2012 | 06:56 AM
i cant imagine the GPS would be all to accurate and the engine would know more.
soldier4402 is offline
Old 06-21-2012 | 12:38 PM
I think they have a device out now that integrates the Smartcraft system with the NMEA system.
I have a Garmin unit that can hook up, but what I'd really like is just a simple dash-mounted gague that would show
speed
fuel useage
RPM
That's pretty much it, and I could do without the speed indicator.
VtSteve is offline
Old 06-21-2012 | 05:24 PM
Originally Posted by mbam
i think you are better of with the mercmonitor. The engine knows how much fuel it is using.
+1
pstorti is offline
Old 09-11-2012 | 04:59 PM
So does the merc monitor; work with the mercrusier 496 engines?
Attached Thumbnails Garmin fuel flow sensor vs SmartCraft/MercMonitor vs ???-merc_diagram.gif   Garmin fuel flow sensor vs SmartCraft/MercMonitor vs ???-gauges_mercmonitor.jpg
qaberdeen is offline
Old 09-11-2012 | 05:31 PM
tlr
Yes, it's working beautifully with my 2003 Mercruiser 496 and Garmin 546.
NMEA engine data is transfered from the MercMonitor to Garmin, and GPS data is transfered from the Garmin to MercMonitor.
FYI I got mine from europeanmarine.org. If you email them with your specific situation they'll put together a kit with everything you need.
tlr is offline
Old 09-11-2012 | 05:37 PM
The reason i was asking is that, i'm considering going to the 496ho for repower..and wanted to add this feature for more dash input..what type of data would i get from either of the two mentioned above, because i dont have the room for the big display units on dash..and what is the size of the merc monitor unit
Old 09-11-2012 | 05:43 PM
The garmin specs show it must be mounted inline, and uses 3/8 barbs. Not sure of the fuel line size on the 496HO, but wouldn't it be bigger than 3/8?
4bus is offline
