Not enough oil for a rocker arm...
#1 piston exhaust valve smoked on me last weekend. The pushrod was clear of debris. This happened after a hard run of about 10 min. @ WOT. Two years ago I had the same problem w/ about three of them, but that time was due to a wrong dipstick installed by an engine builder, I have not ran the engine but a few times since then. They changed out several rockers at that time, so I am kind of assuming that this particular rocker had the middle ball still a little galled up and they missed it.
I do have correct oil level this time, matter of fact about 1/16" over the full mark.
I also thought that this was the last in the line to get oil.
I am using Comp Cams Magnum rollers.
Any thoughts?
Any thoughts?
What exactly happened to the valve? Is it siezed up in the guide? Bent? Break the head off? May have not had anything to do with rocker arms. Need more info than just smoked the valve. What are specs of this engine?
My first though with out any more info would be that you don't have inconel exhaust valves and are melting them down.
I ended up changing it out and then ran the engine, on the hose, several times and seems fine. I am going to find out more tonight and tomorrow.
468ci. Mark IV block
rec. port GM heads
stainless intake/Inconel exhaust
forged GM crank and rods
KB Hyper pistons
RPM Performer Intake
MSD 6AL W/ pro billet dist.
Hardin Gil replacement manifolds w/ Hardin HP500 risers
Comp Cam 230/236 .613 .608 114* lobe seperation
CC Magnum rockers 1.72 w/ a heavy wall pushrod(one piece)
CC pro magnum hyd. roller lifters
Holley 800cfm carb
standard oil pump(not HV)
8 qt. pan-full
Not sure on compression nor HP...
For the parts you got in there I think I would have spent a couple bucks more and went with full rollers. Hope you didn't buy those from Oreilly's at that price! Could have got a nice set of Scorpions or Cranes. You know what your open spring pressure is? Those are advertised for 350lbs. or less.
Nothing happened to the valve it was just fine. By smoked I mean that the half ball at the fulcrum of the rocker arm is all galled up. http://www.oreillyauto.com/site/c/de...359P&ppt=C0146
rec. port GM heads
KB Hyper pistons
Holley 800cfm carb
8 qt. pan-full
rec. port GM heads
KB Hyper pistons
Holley 800cfm carb
8 qt. pan-full
Mark
My engine builder back in IL put them on there, I didn't have an opinion one way or the other only due to my ignorance of a decent built package. Two years later, well, I'm getting there.
No I am not sure what the open spring pressure is. But I do believe that some Scorpions are now on my list after the oil thermostat.
Also I am running Royal Purple 15W-40 in it.
Thanks for the help BTW guys!
I have effectively the same cam or very similar (marine kinetics grind) and I almost put roller tips on, but did the calculation and with that much lift was WAY over the recommended 350lbs for them, I used the scorpion roller rockers. Unless your springs are much lower rate than mine (which could also be a problem) roller tips are not going to work (at least for any amount of time) with over 600 lift.
I doubt your oil had much to do with any of this.
if it was one of the forward rockers and valve you need to go with a 12 qt oil pan,high pressure high volume oil pump,big oil sooler and a oil cooler thermostat...running 10 min @ wot is a killer on the valve trane..
Any thoughts?
Any thoughts?
