-   -   full hyd hoses failing (https://www.offshoreonly.com/forums/general-q/279242-full-hyd-hoses-failing.html)
cloudmaster_321 06-26-2012 08:57 PM
What's the return line psi?
ezstriper 06-26-2012 09:27 PM
return line is next to nothing....you can run simple slip on with hose clamps on those
cloudmaster_321 06-26-2012 09:40 PM
roger
ezstriper 06-28-2012 08:10 AM
Ok, all hoses replaced with 5000psi pressed on ends...should be good to go...all others going back to CP to be checked...Mike there has been awsome to deal with...
cloudmaster_321 06-28-2012 10:08 AM
Agreed, CP has been the best company for customer support that I have dealt with in quite some time.. Thanks Mike.
cloudmaster_321 07-01-2012 08:43 AM
Looks like my alternator bit the dust after this little feasko as well. I kinda wondered how it would fare after being dosed by the powersteering fluid seeing how the line broke inches above it and ran all over it. I tried cleaning it off with water and some simple green, but It's only making voltage with rpm's above 3000 now.
ezstriper 07-01-2012 10:54 AM
have no clue on that one..always something !!! customer did run the boat yesterday and said worked good..thank God !!! had unreal storm roll thru fri eve...91mph winds...destruction everywhere !! 1.5mil without power...marina where I keep our boat no power for days they say..some damage but not to bad...had to clear out fridge yesterday...we have power here, but no phones...
tbanzer 07-12-2012 10:20 PM
I just had a Hardin Inside kit blow a hose off a fitting after being in use for about 10 hrs.. I was waiting in line to put the boat on the trailer, started the boat, turned the wheel and i heard a snap. It felt like something broke inside the helm. Now im concerened with all the fittings. Blew Hydraulic all over the inside of my dash and cuddy. Im not real happy right about now. The worse part is the whole interior just about needs to come out to replace the junk hoses. Its probably not goig to be cheap either.
cloudmaster_321 07-12-2012 10:23 PM
I replaced all mine with crimp on ends. Give Mike at CP a call. I've been in contact with him lately, he plans on sending all this hose/fittings back to his vendor to get checked out.
Rookie 07-12-2012 10:54 PM
What in the he!! is going on with these hoses? Someone is going to get seriously hurt.
Are they tracking the Lot#'s off of these hoses and getting them out of the market?
There is some serious liability here.
I personally use Parker 3000PSI hydraulic hoses with crimp fittings.
