Diesel for corrosion >
Old 06-24-2012 | 03:30 PM
Default Diesel for corrosion
Would diesel be a good engine cleaner / corrosion inhibitor to spray on the motors to keep them looking good?? I know WD40 is bad as it swells the wiring insulation - so are there any reasons not to use diesel??
Austin is offline
Old 06-24-2012 | 04:33 PM
Default fixx
no! once it gets hot it ignites like gas..you need to look into fluid film,,its pricy but its one of the best out their..
http://www.fluid-film.com/
BTW you can use it on anything! as a wax and wipe it down..on your outdrive just spray it on and wipe it off and it looks like you took a buffer to it..i buy it by the 5 gallon bucket for the salt trucks in the winter time..
look at the pics at the bottom of the page..
http://www.theruststore.com/Fluid-Fi...l-P182C67.aspx
FIXX is offline
Old 06-25-2012 | 01:51 AM
another down side to diesel even if boat doesn't burn to the waterline...it smells bad!!!
dereknkathy is offline
Old 06-25-2012 | 07:21 AM
That's a very good point- so obvious I didn't think of it. In my defense I don't think it's hot enough in the engine compartment to ignite diesel as you really need to hold a open flame to it before it'll light. WD-40 burns too.... hold a lighter up and spray the can into it . Thanks for the Fluid-Film link it looks like really good stuff.
Austin is offline
Old 06-25-2012 | 10:08 AM
i use marvel mystery oil,that chit really works good,i put it in a spray bottle,spray it on,then wipe the excess of with a paper towel.
mike tkach is offline
