I need an oil temp sender and is this a good location?loactin >
Old 06-27-2012 | 11:39 PM
phughes69's Avatar
Default I need an oil temp sender and is this a good location?loactin
My boat has factory oil temp gauges and the existing senders are at the bottom of the oil pan (cast aluminum pans) Is this a good spot? Also one of them is broken. What ohm range might it be?
phughes69 is offline
Old 06-27-2012 | 11:42 PM
what brand are the guages?
mike tkach is offline
Old 06-27-2012 | 11:53 PM
phughes69's Avatar
The gauges are the stock ones that came
On the boat in 1980. For the life of me I can
not remember what they say on the bezel
Old 06-28-2012 | 07:07 AM
Mine are in the pans.
THRILLSEEKER is offline
Old 06-28-2012 | 07:41 AM
+1 So are mine.
That old scarab.....maybe Nordskog gauges? Stewart warner?
You can take the wire off the sender, and ground it with the key on. See if the gauge pegs to full HOT. If it does, maybe the sender is bad. if it doesnt, check wiring.
MILD THUNDER is offline
Old 06-28-2012 | 10:50 AM
phughes69's Avatar
The tip of the sender where the wire bolts to broke off, that is why I need a new one
Old 06-28-2012 | 11:07 AM
Youll need to find out what brand gauge you have, or take the other sender out and do some ohm readings. Most of the american stuff, is compatible. VDO style, might require a special sender.
Old 07-05-2012 | 09:03 PM
phughes69's Avatar
here is a picture of my oil temp gauge. it is a 150-300 range. Does anybody know what type of sender I should use with it?
Attached Thumbnails I need an oil temp sender and is this a good location?loactin-oil-temp.jpg
Old 07-05-2012 | 09:19 PM
Looks like a old faria or teleflex gauge. I'd think this will work fine
http://www.cpperformance.com/p-13075...si-gauges.aspx
Old 07-05-2012 | 09:28 PM
obnoxus's Avatar
Charter Member #1171
My boat has factory oil temp gauges and the existing senders are at the bottom of the oil pan (cast aluminum pans) Is this a good spot? ?
Its the best spot,,,,,the best thing to know is the temp going into the motor
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
