blown up again (extension box)
I agree that balancing is not likely the issue; however, DynoTech is where we have our driveshafts rebuilt and balanced in Detroit. Marc is right on. Once the X-dimension is set, re-align the engines to get the targeted driveshft angle. This is a good winter project!
[/url]
[/url]
I remember chatting with my buddy Rob about this a while ago so while greasing my drive shafts yesterday I looked and sure enough its the same setup. Extension box fluid change! LOL it never ends with these boats!
Interested in adding a fluid reservoir to monitor the level. How would I go about that? How much fluid does it hold normally? How do you currently change the fluid? How much fluid would you use if you added a reservoir? Can you overfill it?
The stellings boxes on my last boat just had a grease fitting there.
Thanks!
Thanks!
Thanks!
Thanks!
