500 efi issue
Originally Posted by Griff
(Post 3724136)
Because the water sep fuel filter on the port engine is between both engines and gets hotter causing the vapor lock condition. Merc makes a booster pump kit that will fix the issue.
I didn't research 500efi's when I was dealing with this issue, but the priming pump from Mercury completely cured my vapor lock issue on 502 MPI. Maybe same fix available for Cool Fuel 500's.
We were out all last weekend on the Ohio, and never experienced it once. It was 103-105 ambient (as you probably know). I never opened the hatch to cool, and didn't have the blowers on for extended periods of time after parking - which was my ritual last year - last year (first year we owned boat), it would vapor lock at anything above 90 degrees (may have been coincidence). The pump is an easy install, and if you are handy with wrenching, you can do it yourself - essentially plug and play. Terry
Originally Posted by Hank36
(Post 3724001)
Ive got twin 500 efi's in my boat and the port engine want hardly start and run after running it for a little while and then sitting around in the water when the air temperature gets above 100 degrees.Ive changed the fuel filters and even put a new fuel pump thinking that was the problem.Has anybody here on OSO had this kind of problem with there boat and if so what do I need to do to cure this?It runs fine when the air temp drops below 100 degrees......Puzzled.... Hank 36
500 efi issue
Thanks for the compliment Big Red,tried calling Eddie but I guess he is out of town..Easyrider do you have the part# for the kit you purchased?Hank36
My starboard always did it, 2000 merc 500EFI's. I put a 150$ holy pump in the fuel line before the fuel filter and it never did it again. I wired it to my ignition so when the key was on, it was on, when the key was off, it was off. very easy fix, and same thing merc ended up doing a few yrs later
Part numbers are in this bulletin. However, I believe they've been superseded since this was published. Any Merc dealer should be able to get you the latest level parts.
http://www.offshoreonly.com/forums/g...fuel-pump.html I scoured the internet looking for best price. I believe I paid about $400 shipped from somewhere in Florida. I can't find the invoice at the moment. Terry
(Post 3724381)
Fuel pump
Originally Posted by Boomer35
(Post 3724397)
| All times are GMT -5. The time now is 01:33 PM. |
