SBC oil leaks. Gasket recommendations? >
Old 07-07-2012 | 10:45 PM
Default SBC oil leaks. Gasket recommendations?
I have a pair of 383's. I spun a coupler this past week so the engine is coming out and I've had a few small nagging oil leaks. I'm going to reseal everything except the heads. Any gasket recommendations and gasket maker. It looks like small oil pan drip and possibly back bottom of intake. Only when under load and above 3000 RPM's.
nauticaL ILLUSIONS is offline
Old 07-07-2012 | 10:56 PM
you didn,t say what year the engines are,i like the fel-pro 1 peice pan gasgets,and also like their intake gasgets,but i dont use the end seals,i use the right stuff silicone rubber,it never leaks.
mike tkach is offline
Old 07-07-2012 | 11:05 PM
The engines are Gen 1. I like the sound of never leaks. I'm over oil in the bilge.
Chris
Old 07-11-2012 | 08:11 AM
I just had to replace an oil pan on my stbd engine due to rot around the drain plug. what a pain in the azz.
BIGMC69 is offline
Old 07-11-2012 | 09:28 AM
+1. I do the same thing an use fel-pro.
akaboatman is offline
