Lifting engines from boat >
Old 07-11-2012 | 10:16 AM
Originally Posted by bigmike253
shoot I don't even have a tree in my back yard. I think I'm going to make one.
Your going to make a tree??!!??!!
Are you pulling them inside or outside? If you have a tall garage, there is a pretty easy setup with a chain fall. Nothing for you if you are outside. I use a fork lift with a boom extension, real nice and easy.
Originally Posted by sprink58
I bought them for $4000 cash Builder was happy and so am I.
And we still hate you for this one man! Still rubbing it in, still rubbing it in..... Ha ha.
Brian
befu is offline
Old 07-11-2012 | 02:54 PM
I built a wood gantry. $120 worth of lumber and a 1 ton chain fall. I needed a lot of height so garage, tow truck etc. would not work. Don't underestimate the lifting height you may need. I used two 12' 4x4 for the vertical posts gusseted by 3/4" plywood and the header was two 12' - 2x8's bolted together with 3/4 plywood gussets as well. Worked like a champ and I could disassemble it when done. No stability issues.
Trash is offline
Old 07-11-2012 | 03:10 PM
Originally Posted by seafordguy
Go to harbor freight and buy their gantry crane - for under 500 bucks you'll be up and running.
Where the heck were you when I rebuilt my motor, could have saved myself a ton of money. Next time I'll know.
ThisIsLivin is offline
Old 07-11-2012 | 08:28 PM
Thats what I did. I have to lift a complete motor and trans 12' in the air for the race boat. Best 500 I ever spent.
f_inscreenname is offline
Old 07-11-2012 | 09:05 PM
I have a I beam in my building with a trolley and chain hoist. Dont go cheap on this deal, if it fails you could damage your boat or die. Find somone local that has the right setup.
jeffswav is offline
Old 07-11-2012 | 09:33 PM
+1 works great just pulled mine,and dropped in a new one.
michaelb63 is offline
