temp sending unit >
temp sending unit
temp sending unit
Old 07-13-2012 | 01:11 PM
Default temp sending unit
454 carb has 2 sending units in the tstat housing. Which is for the alarm and which is for the gauge, or does it not matter?
tnc110 is offline
Old 07-13-2012 | 01:25 PM
i think the alarm has the blue stripe and sending unit is plain brown
Drock78 is offline
Old 07-13-2012 | 04:29 PM
Just ground the wire to find out.
whoya is offline
Old 07-13-2012 | 04:35 PM
Thumbs up
Originally Posted by whoya
just ground the wire to find out.
+1
akaboatman is offline
Old 07-13-2012 | 05:50 PM
The sending units are different...does it matter which is hooked to which?
tnc110 is offline
Old 07-13-2012 | 06:32 PM
yes it matters. One is basically a on/off switch for the warning buzzer. The other is a resistance type for a guage.
MILD THUNDER is offline
Old 07-13-2012 | 08:56 PM
My gauge sensor looks like a 3/16" threaded bolt. The alarm sensor is oval shaped.
Wes Burmark is offline
Old 07-13-2012 | 09:59 PM
Oops. I was thinking you were trying to figure out which wire was which. As Wes said.
whoya is offline
Old 07-14-2012 | 09:32 PM
ok, so which is which? They both have the same connector. I have to pull my thermostat tomorrow, as I think it is stuck open, so I will be able to look at the inside of the sending units. But I don't know what to look for?
tnc110 is offline
