305 carburetor >
305 carburetor
305 carburetor
Old 07-13-2012 | 07:27 PM
Default 305 carburetor
Looking for a rochester carb 4 bbl merc.# 1347-9661a3
I have put in a new fuel pump and 2 people have rebuilt it and gas still comes over the top and runs down the intake. Fuel pressure is 6psi.The one guy told the float is set very low he has tryed it at different heights. what do you guys think?
dennis r is offline
Old 07-13-2012 | 08:17 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Sounds like the gasket under the needle seat is leaking . Can also be a bad float or needle . These are the three things that control fuel flow and fuel level , if any one of these are bad the carb will flood .
the deep is offline
Old 07-13-2012 | 08:48 PM
Try the Carburetor Shop in Ontario, CA. Google them. They have done an awesome job for me in the past.
Wes Burmark is offline
Old 07-13-2012 | 09:18 PM
put a new float in it and a new needle and seat also with a new gasket
dennis r is offline
Old 07-13-2012 | 09:36 PM
the deep's Avatar
Fast Singles Club
Was it flooding before it was rebuilt ? Is the needle hanging towards the float or away from it , talking about the little needle hanger . It should be toward the float . Seat snugged down good ? These carbs don't just flood for no reason , something is being overlooked .
the deep is offline
Old 07-13-2012 | 09:41 PM
I will look at it in the morning
dennis r is offline
Old 07-14-2012 | 05:35 PM
Well that was not it I put on a fuel pressure regulator and it maxs out at 6 psi . th e carb runs over at that but if I turn it down to 4/5psi it will run just fine why is the new fuel pump to much psi for the carb.
dennis r is offline
Old 07-16-2012 | 04:31 PM
mcollinstn's Avatar
A properly sealing float/needle combo will seal at up to 9 psi.
6 psi is perfectly fine.
You need to check your float for a leak (if it's brass) or see if it may be hitting something that keeps it from closing all the way, or simply replace the needle and seat.
MC
mcollinstn is offline
Old 07-16-2012 | 06:52 PM
I did all that new float new needle and seat
dennis r is offline
Old 07-16-2012 | 08:08 PM
This might sound crazy but you might have a "bad" new needle valve and seat...it should hold 8~9 psi if it's correct.
sprink58 is offline
