Major RPM Problems?? >
Old 07-05-2002 | 10:10 PM
1Boatnut's Avatar
Default Major RPM Problems??
1990 502 mostly stock,usually 5200 rpm's max. I was out on the 4th ,and as I started to accelerate ,I was able to acheive 6000 rpm's and still had 1/2 throttle left. Right before this happened,I did hear a noise like I hit something. I drove back to the launch at idle speed. I pulled the prop off,and found a piece of plastic behind the prop. Something from the river not the boat. I take the boat for another blast,and now it seemed normal,but I lost about 5mph on the gps.Now the rpm's seemed back in the range. WTF......any ideas??
1Boatnut is offline
Old 07-06-2002 | 09:38 AM
What are you runing for a prop?? If you are running a Merc Mirage plus or bravo, sounds like you spun out the plastic hub.
The good news is it is replacable, probably not a bad idea to go to a solid hub with the 502.
TomR is offline
Old 07-06-2002 | 10:43 AM
1Boatnut's Avatar
TomR.....thanks for the info,but I am already running a solid hub in a 23 Mirage..
1Boatnut is offline
Old 07-07-2002 | 05:31 PM
blue thunder's Avatar
Sounds like you straightened up a blade. Do you notice any vibration?
BT
blue thunder is offline
Old 07-07-2002 | 11:15 PM
1Boatnut's Avatar
b t...the props fine. No vibration. I am starting to suspect either the coupler,or the clutch cones. Any thought's anyone. And ,how do I diagnoisis??I did talk to a friend who owns a Marina (shop),and his thoughts were the same as mine
1Boatnut is offline
Old 07-08-2002 | 09:03 AM
How many hours are on the motor and the drive ? Sounds like a coupler to me, though it could be the clutch in the drive. Did you smell something burning when it happened?? The smell of burning rubber is a sign of a bad coupler.
TomR is offline
Old 07-08-2002 | 12:49 PM
From my experience couplers don't partly fail. It's all or nothing. If it could do that though you would notice it mostly trying to get on plane... not at wot.
BT
VIPER7
7
05-02-2008 10:11 PM
1BIGJIM
5
07-04-2006 12:50 PM
THRILLSEEKER
4
08-08-2002 06:50 AM
LLcoolBaja
6
06-09-2002 03:52 PM
Waterfoul
01-20-2002 07:14 PM
