Is the mph correct for specs?? >
Old 07-23-2012 | 05:11 PM
  #31
The 58mph@4600 rpm is correct with a power tech 20 pitch
Martin718 is offline
  #32
check your timing. mebbe you don't wanna adjust cuz computer will just compensate, but see what idle is and see what 3500 with the advance all way in is timed at. sounds like it is too retarded. the timing, i mean...you might want to take off sun pad-hatch and have a buddy run it up on plane while watching timing advance. the computer might advance differently with no load on engine at higher rpms on the hose in the driveway.
dereknkathy is offline
Old 07-23-2012 | 05:20 PM
  #33
Idles perfect at 600-650 rpm. How can I check timing without the scan tool to set in service mode?
Old 07-23-2012 | 05:23 PM
  #34
I'm sorry Martin, most of my posts were based on me thinking you had a 7.4l mpi, which is the 330 hp cast internal engine. You can build up what you have fair easy, my bad :/
4bus is offline
Old 07-23-2012 | 05:29 PM
  #35
articfriends's Avatar
So if you are going 58 mph with a 20 pitch at 4600 your slip would be ZERO (impossible) or you have a 1.36 ratio drive (or even taller). You might have other problems but the DRIVE RATIO is your main problem. You need like a 18 or 16 pitch prop to get your speed and rpm's right but that doesn't really exist in a stainless bravo prop so what you really need is to change outdrive gearing to 1.50. Your only running 4600 with a 20 pitch, your motor peaks at 5100-5200 so you are probably about 40 hp or so BELOW the peak , until you resolve this you will chase your tail, Smitty
I would buy the right drive gears or a diffrent drive.
articfriends is offline
Old 07-23-2012 | 05:31 PM
  #36
He's turning 4600 with a 20 pitch though, if you crunch the numbers he must have a 1.36 ratio drive and boat is still propped too tall, needs correct gears before he changes alot!\
http://www.rbbi.com/folders/prop/propcalc.htm
Old 07-23-2012 | 05:42 PM
  #37
I tried to run a mirage 23 pitch 3 blade yesterday and it took the trim fully up to get the motor to get to 4200 rpm and would only run 52mph... How can I determine the drive and what are you thinking the problem is?
Then something is not right. It should run at least 60mph at 4800rpms+.
Looking at a 500 with pro charger and looking at xr drive
Why not just buy a 40k boat that is worth 40k instead of spending 15k on 25k boat that will still be worth 25k when you're done.
Griff is offline
Old 07-23-2012 | 06:06 PM
  #38
Griff, if you crunch his numbers (58 mph with 20 pitch at 4600) it comes up as ZERO slip with 1.50 gears, boat wont pull a 23 except to 4200, only turns a 20 to 4600 BUT most the speed is there), I strongly feel he has a set of 1.36 or taller gears in hbis drive, he will NEVER get it to run right until that is taken care of, Smitty
Old 07-23-2012 | 06:43 PM
  #39
agreed....my 270 laser ran 61-62 with the 454/385 , bravo 1.5 and a 21P mirage...4900/4950....before i added the whippled engine !
pqjack is offline
Old 07-23-2012 | 07:09 PM
  #40
Yea it's a 454 mag MPI 385 hp
