10 meter trans . bw >
10 meter trans . bw
10 meter trans . bw
Old 07-30-2012 | 06:39 PM
ROB FREEMAN's Avatar
Default 10 meter trans . bw
does anyone know if you have to have the motor running to check fluid on theese trans . thanks .transmissions are new to me . thanks rob
ROB FREEMAN is offline
Old 07-30-2012 | 06:46 PM
rob,i check mine as soon as i shut the engone off,i have dry sump trannys.
mike tkach is offline
Old 07-30-2012 | 06:48 PM
mcollinstn's Avatar
BW Velvet Drive?
The trans fluid will measure differently when hot versus cold. Running in neutral is the usual way to check them. Look on your dipsticks and see if they are marked hot/cold.
Velvet drive transmissions hold up well with stock power, and the main thing you need to do is make sure they don't ever get hot. If you lose a water pump impeller, always backflush the trans coolers to make sure there are no rubber chunks stuck in there.
MC
mcollinstn is offline
Old 07-30-2012 | 06:56 PM
thankyou . thankyou
Old 07-31-2012 | 05:57 AM
Mbam's Avatar
Offshoreonly Advertiser
Here is what we recommend
http://www.cyborgtransmissions.com/S...tructions.aspx
Mbam is offline
Old 07-31-2012 | 08:01 AM
Rookie's Avatar
Originally Posted by Mbam
Here is what we recommend....
"The distance between the “full hot” mark and the bottom of the dipstick is NOT an operating range."
This made me laugh.
Rookie is offline
