how to backflush a 496 ho
Hi, i have never owned a closed looped 496ho before. It runs a little hot after a few wide open runs. I am going to check the sea pump but how and what do i flush. I have been told to flush the heat exchanger and hoses. Is it posible to screw anything up if i do it wrong? how and were would i install a gauge to check water pressure? any help would be great. Pics would be awesome. sorry to be an ignoramus. Oh, if it matters it has a whipple kit. Dustin whipple has been a big help on what to check and flush, i just dont know how. Thanks!
I had trouble with overheating a couple of years ago. I checked the heat exchanger by pulling the end caps off & looking through. That wasnt the problem, the oil cooler & p/s cooler are before that in the cooling system. I took the inlet hose off the heat exchanger & put a spray nozzle in the hose to backflush. Worked fine for me. The waterpump housing is a problem as the ends get grooved & reduces water pressure. Hardin marine makes a stainless housing replacement for about 350.00 as compared to 600.00 for merc. Hope that helps, Randy
Order a scan tool. It's a smart investment for anyone with that engine. It will allow you read the seawater pump pressure and the the various temperature sensors so you're not shooting in the dark.
http://www.rinda.com/marine/marine.htm#merctool |
Originally Posted by boatnutt
(Post 3744847)
That info was sent to me when I asked the same question by another oso member (knockld ) I did exactly what he wrote ( what I forwarded to you ) and it fixed my problem. The guys here are awesome and always willing to help!
Rick |
You guys are awesome! thank you!!!! will let you know if it helps.
Originally Posted by NightHawk
(Post 3744955)
http://www.rinda.com/marine/marine.htm#merctool You should have 3-4 lbs at idle. When was the last time you changed your impellor? |
Originally Posted by Dave M
(Post 3745434)
+1
duh, i didnt read the post in front of your. i will order the tool.
You said your Temps are getting up there, do you know if there is a separate water pick up for your inner cooler, or is it one pick up teed off?
| All times are GMT -5. The time now is 04:47 PM. |
