Everything just died
Open your seat where the two Perko switches are. About 3 inches above the switches there are breakers. You may have to put your head in there to see them. Typically the issue that caused mine was an issue with trim grounding out.
Disconnect and hook straight to large post on starter thing should come back on. Then you know.
These are one of a couple things that can cause everything to go out.
Location: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
1 Post
The 50 AMP breaker on the ST side Mercathode popped. We tightened up a few loose wires, reset it and all seems well. If it does it again, there must be something we missed.
