How much space is required to short stagger? >
Old 08-09-2012 | 09:26 AM
Originally Posted by cougarman
Could always put your tranny's in the Stellings Box like
Check300 did on his #6 set up for lack of room.
Saw this boat up close a few years back on Hardy- owner was very friendly. That motor is a work of art!
northerndoc is offline
Old 08-09-2012 | 12:14 PM
Maybe I'm not asking the question right.
If there is anyone out there running a staggered setup with brovo style drives if they could measure from the inside of the transom to the front of the forward engine and post the findings. It does not matter what manufacture or if it a full or short stagger as long as its a staggered running brovos. I believe you could get a way with around 70-75 inches. Just trying get an estimate on the veribility from other setups.
Jason3603 is offline
Old 08-10-2012 | 05:38 AM
Payton's Avatar
Charter Member #927
I will measure mine this weekend.
Payton is offline
Old 08-10-2012 | 03:52 PM
Thanks man! This info will be very helpful.
Old 08-10-2012 | 04:28 PM
Mbam's Avatar
Offshoreonly Advertiser
See if these help.
You can see if you widen them up a little bit, maybe to 24" you can shorten it up a lot. One problem you run into if you get them too close is the routing of the forward tail pipes.
Attached Thumbnails How much space is required to short stagger?-525_bravo_stg_top.jpg   How much space is required to short stagger?-525_bravo_stag_side.jpg
Mbam is offline
Old 08-10-2012 | 06:14 PM
This is great info! Thank you very much. From the pics this looks to be a full staggered bravo setup. I run blower motors so Iwill have to have them a bit closer. It looks like if I have 77 inches I can make a go at it.
Old 08-10-2012 | 06:21 PM
That is one cool azz setup!!!!
POWERPLAY J is offline
Old 08-10-2012 | 06:41 PM
Mbam's Avatar
What drives are you using? I might have a drawing of that also.
Mbam is offline
Old 08-10-2012 | 07:17 PM
I am going to run the imco -4's. with blower motors. You wouldnt have any drawings of a blower/xr setup, that will get me even closer to the ballpark.
Old 08-11-2012 | 06:49 AM
Mbam's Avatar
Do you have your engines out of the boat? Set them up on the floor and move them around, see what you come up with. That is the best way.
Mbam is offline
