Wet Vs Dry Exhaust >
Wet Vs Dry Exhaust
Wet Vs Dry Exhaust
Old 08-08-2012 | 11:31 AM
Default Wet Vs Dry Exhaust
looking at upgrading my exhaust from a 4" wet gil risers to 4.5 dry. I had considered headers but after some research it appears most people dont get much of a performance gain over the manifolds i already have. So whats all the advantages and disadvantages of the wet vs the dry. other than i know the 4.5 dry is going to sound better. Engine is a modified 525SC. 468 cu in. Roller cam with .600 lift. on a regular engine dyno it made 570hp and 600 ft lb.
spark plug is offline
Old 08-08-2012 | 11:33 AM
The only thing you will gain is noise.
Griff is offline
Old 08-08-2012 | 11:39 AM
I doubt you will see any power. dry is super loud though and even if you love the sound will get annoying through a long idle zone.
VetteLT193 is offline
Old 08-08-2012 | 02:19 PM
Too Stroked's Avatar
Everybody I know who ever went to a dry system is either deaf or switched back to wet. Just not worth it.
Too Stroked is offline
Old 08-08-2012 | 03:05 PM
Have 2 950hp blower motors with Stainless Marine Completely Dry 5" tails and they arnt loud enough!!!
bigfarmer is offline
Old 08-08-2012 | 04:40 PM
Two 800HP blower motors with Stellings headers and dry tails, it aint that bad....
Dry Tails can get really loud idling if your running a big compression, long duration cam, big ported heads, etc. But most supercharged marine engines are low compression, modest cams, and really aint that bad at idle. Ever heard a stock 454 suburban engine with open headers, then compared it to a 700HP N/A 454 strip motor with open headers? The suburban 454 sounds tolerable, the 700HP sounds like a monster.
While at certain HP levels, you may not see much gain going from a GIL manifold to a header, but...at some point a good flowing set of headers DOES make a difference. On a 450HP engine, no, but a 900HP engine, it can mean alot.
MILD THUNDER is offline
