GPS tattle tale stuck at 70 ?
Got a Gaffrig GPS "think it's a Lavorsi" Worked fine for the last few years and is now Stuck at 70. Tattle tale wont erase or recall. Un plugged the power, swithed the antenna and still Nothing but 70. Any Ideas ???
Maybe it has an internal battery backup
When you turn on the key and the GPS pegs if you leave the key on but do not start the engine for about 5 seconds or so it will go down close to zero. As my boat was 5-years old when I bought it I had the dealer replace the battery as he said they generally last only 5-6 years. I'm not sure what happens when the battery goes but I do remember there was a thread on this about one month ago. Do a little search and you may find out a cure.
Thanks for the tip but it's always stuck there. dosesnt matter if the key is on or off. Tried another antenna off a buddys GPS to see if it's the battery and nothing changed. I'm guessing the guage **** the bed.
Originally Posted by monkfunk
(Post 3757066)
| All times are GMT -5. The time now is 09:39 AM. |
