To much water pressure????????
if they are raw water cooled engines then that is alot. if they are closed cooling then that is right around where mercury wants them to prevent hot spots in the headers. they may have fixed the problems by now but the early HP525 headers had problems if you ran the pressure too low.
I have one adjustable one from Eddie Marine and one expensive plastic Merc one. Merc one is always 30 lbs
the adjustable run I run at 15 lbs.
I would recomment Eddie Marine and since you are in fresh water, after the oil cooler before it enters engine.
And if this a relief valve where do I plumb the relief to?
