Carpet Adhesive/Glue Removal >
Old 08-23-2012 | 09:10 PM
Default Carpet Adhesive/Glue Removal
Just picked up a old Malibu Trantrum Ski Boat and have removed the carpet to have some type of non skid flooring sprayed in such as bed liner. I have already scraped up all that I can and followed up with pressure washing with a zero tip and have about 70% of the glue reoved. The remaining 30% of the glue just will not budge. Does anyone know of any chemical adhesive remover that is fiberglass & gelcoat friendly that will finish the job and get the remaining glue off and out of the low spots/valleys of the fiberglass roving . Not wanting to grind, wire cup wheel or sand.
Thanks,
Cliff
cliff_m_b is offline
Old 08-24-2012 | 10:06 PM
try wilsonart 131
phragle is offline
Old 08-25-2012 | 09:21 PM
Thank you
Old 08-25-2012 | 09:56 PM
c_deezy's Avatar
3M adhesive remover. Google it.
c_deezy is offline
Old 08-25-2012 | 10:30 PM
Adhesive remover from home depot if water based. Goof off if oil based.
f_inscreenname is offline
