-   -   Need cam help (https://www.offshoreonly.com/forums/general-q/283467-need-cam-help.html)
johnnyboatman 08-25-2012 09:12 AM
Need cam help
Ive got talldeck 540s, with big brodix heads, 10.2.1 comp, 1150 dominators, cam# not sure, but on the dyno they pulled 650tq, 620hp i think the cam is the problem the builder says the heads are the prob. The heads are 365 i think is the number. I think the builder used some 500efi cams, im just wondering why these didnt make 700hp as to thats what i wanted and stated to the builder. So if any of you guys have some 540s single carb no blower please give me your cam specs so i can compare to see where i went wrong.
endeavour32 08-25-2012 09:21 AM
I'm pretty sure the 500 EFI cams are very close to the hp 500 cams. If thats true then the cams are your problem as they would be fairly small for your build. The 525 cams are quite a bit more powerful and would get you better results. The best thing to do would be to call Madera and have him spec out two cams. If your going to replace the cams with new roller cams the price will be the same if not a tad less and your engine would be optimized for how its built.
kvogt 08-25-2012 09:34 AM
For off the shelf cams, the crane 651 or 741 cam would do well. Or contact rmbuilder on here.
fbc25el 08-25-2012 10:08 AM
I have a 540 with 9.7 to 1 comp. 1050 domimator. I would contact Bob Madera (Rm Builder 585-654-8583). He made my cam and it works great.
johnnyboatman 08-25-2012 11:25 AM
yes i think my cams are to small, guess i will get the numbers and go from there, when we started this the builder said 700hp was not a problem, now there done and 620hp is not what i wanted, but he says my heads are old style. there big brodix alum bb2 have been ported and other stuff. im thinking the cams are to small
johnnyboatman 08-25-2012 11:26 AM
fbc25el what hp did yours make.
fbc25el 08-25-2012 11:56 AM
I did not dyno the motor. But I had a crane cam in it and it would only pull to about 5400 rpm. I put one of Bob's cams in it and it would pull strong to about 5900 rpm. That was the only change I made.
articfriends 08-25-2012 10:36 PM
Them little baby cams are holding you back, I made 657 hp with my 8.4-1 540s (less than ideal compression) with blower belt off with a cam from Bob Madera, with 10-1 compression and a cam ground optimized for running N/A I would expect a easy 700 hp, Smitty
johnnyboatman 08-27-2012 01:17 PM
the specs are int-dur- 303-612-lift exh dur-311-631lift 114 lobe sep is this a small cam or?
johnnyboatman 08-27-2012 07:58 PM
ttt
