Cyl wall scuffing >
Cyl wall scuffing
Cyl wall scuffing
Old 08-29-2012 | 10:13 PM
Originally Posted by JeremyAnderson
On a fresh engine, I would venture to say the scuff was from not enough piston to wall clearance. Marine engines need a couple extra thousanths to deal with hot pistons and cold coolant temps.
It usually takes a good bit more water temp than 230 to scuff a piston from overheating. Just my 2 cents....
i agree,i like .001 xtra wall clearance on marine engines,as far as 230 deg water temp,that in itself probibally did not scuff the walls,but that combined with wot running,detonation probibally occured.
mike tkach is offline
