Help! I broke it!
Most likely bad gas. My boat sat for the last 6 weeks until last Saturday. Had 15 gallons of premium in it, filled it with 45 gallons of new premium and had no problems. My friend from work also had his boat sit for the 6 weeks, he took his out on Friday and only added 5 gallons on top of 10 old gallons and had problems similar to yours. He called me that Friday night because we were meeting on the river Saturday and I told him its probably bad gas so top the tank off with new. And Saturday his boat ran great with the new gas.
OK IM going to pull all the plugs and inspect tonight, I have a comprassion tester so I will do that while the plugs are out also. I will report back any findings thanks guys. I'm hoping it aint bad gas because if it is there is alot in there and I dont know how I could drain it all.
If its a mech. Fuel pump, check the bypass line running from the pump to the carb. If fuel is coming out and flooding the carb. Replace the fuel pump. Smell the oil if it smells like gas change it also. If there's enough gas to puddle in the intake theres enough gas to pass the rings.
An '84 350 is an old work horse and not as finicky as the new Hi tech engines. That said, I'll review some facts.
Fuel in intake...could be from Choke or you pumping the throttle.
No water in separator. Should not be any in carb. then.
If you are fueling from a gas station it will be Ethanol and it will Phase separate with moisture and leave behind two differrent products. Both bad but the Ethanol water combo should separate in filter. They remaining product does not burn well due to being stripped of it's volatility factor. I lost a 350 last year due to bad gas. Build up gum on intake valves and stuck one. Engine had 40hrs.
Spark plugs...Did you remove them ? how did they look ? If they were Black and carboned up, that is definitly a sign of BAD GAS. How does your gas smell ? sour or does it bite your nose ?
OK so I got some time to work on it yesterday heres what I found....Spark plugs were not black and carboned up, but were all saturated in gas, like fouled from all the gas on them. I didnt have my carb on the engine (its in pieces) so I couldnt do the compression check, but I did replace all the plugs while I was there. I also replaced the fuel filter while I was there and primed it with fresh fuel, just waiting on a carb now. I have been using all 92 octane gas from a gas station, no marina fuel as I trailer the boat everywhere. I will interested in trying it with another carb to rule that out.
