Electrical issue. It is not running 240 or it would pure steam.
you can check sender with ohm meter(0-90) hooked onto sender in hot cup or pot, same with t-stat. normally when guage acts up on panel it will have partner guage to act up also, so check grounds and power connections on guages.
Are you pumping water out the exhaust? Just might be a bad impellor.
Found one problem - left out an engine drain plug......
Doh! |
Overheat
Originally Posted by MOP
(Post 3766844)
Go over your ground connections behind the dash, my 2 cents is on electric gremlins.
Originally Posted by Nicolasticity
(Post 3815732)
Doh! |
Originally Posted by Griff
(Post 3816386)
You didn't notice your bilge pumping out a bunch of water????
Guess if you drove it long enough, the motor would have cooled down just by all the water surrounding it. :)
probably the wrong sender on the motor, you probably have a oil temp sender in there. different ohm's.
Is that your tow vehicle in your avatar? Please start a thread in the towing section of this site to keep us entertained this winter :D
| All times are GMT -5. The time now is 10:47 PM. |
