Are vortecs sufficient for a 383? >
Old 09-10-2012 | 11:04 PM
  #31
Originally Posted by mrfixxall
ummmm find a little m block,,why trash a complete running engine? the newer gm blocks are for chit,,cylinder walls are real thin,.030 oer then you have problems and the blocks flex like crazy when you grind the webbing of the block for rod clearance..
this is going to be my next block http://www.dartheads.com/products/en...ll-blocks.html
im going to try and get 454 cid of if i can find a crank i may go over that...if your gonna spent the time and money you may as well spend a few more and go bigger..
That thought has crossed my mind, if the funds allow I will def go for a better block, if not I may just grab another gm block and go, put the 350 in the corner for back up
87MagnumII is offline
Old 09-11-2012 | 03:12 PM
  #32
GPM
Have you checked out any of the crate motors Summit or Jeg's, don't remember what drive you are running, that may be your limiting factor.
GPM is offline
Old 09-11-2012 | 03:57 PM
  #33
have thought about it but it would almost be to easy lol, then i couldnt get on here and ***** about all my problems
im running an alpha but dont really care if i blow the drive, i can buy a lot of sei drives for what it would cost to switch to bravo. plus im easy on it out of the hole and in the rough
Old 09-11-2012 | 04:09 PM
  #34
GPM
You could do the 396 sbc just to be different.
GPM is offline
Old 09-11-2012 | 05:01 PM
  #35
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Wink
How bout a 410 sprint car motor .......Maybe the Pa. Posse has one layin around .
the deep is offline
Old 09-11-2012 | 05:24 PM
  #36
GPM
Might have a 434 sitting in the corner somewhere.
GPM is offline
Old 09-11-2012 | 06:00 PM
  #37
the deep's Avatar
Fast Singles Club
http://speedomotive.com/default.aspx
This is where i bought my 383 parts . It is an awesome engine , too bad all it does now is sit on the garage floor .
the deep is offline
