Cylinder ingesting water >
Old 09-09-2012 | 10:30 PM
Keytime's Avatar
Default Cylinder ingesting water
Trying to help out a friend here... he has a small ski boat (not even sure of the engine). He shut off the engine while floating and the engine starting dieseling. He flooded it to get it to shut down. Later, he tried to start it and nothing. He removed the spark plugs and one cylinder was full of water. He cleared it out and the boat started and ran fine.
When he got home he did a compression test and it checked out fine and the boat runs just fine. Did he possibly suck some water through the exhaust when dieseling? Sounds like he might be lucky he didn't bend some valves.
Any help would be appreciated. Thanks.
Keytime is offline
Old 09-10-2012 | 01:01 AM
Yes
Trash is offline
Old 09-10-2012 | 07:43 PM
Originally Posted by Trash
Yes
Yes, likely reversed rotation, Common result. Better determine why it dieseled. It will happen again
tunertech is offline
Old 09-10-2012 | 07:50 PM
What is dieseled? Noob question, lol
mgoblue06 is offline
Old 09-10-2012 | 07:56 PM
When a gas engine continues to run after the ignition (spark) is turned off, like a diesel which does not have spark plugs but instead uses heat and pressure to cause combustion.
4bus is offline
Old 09-10-2012 | 08:17 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Sounds like a diesel too when it's happening . Too high idle and improper ignition timing will cause it among a couple other things .
the deep is offline
