CMI gaskets
Old 09-10-2012 | 10:36 PM
Default CMI gaskets
Would like to have input on which header gaskets to use for CMI E-tops with (cool collar)? Heads are GM 088.
Also does the E-tops typically use rope seal or gasket?
(I'm currently away from the boat).
badluck is offline
Old 09-10-2012 | 11:03 PM
E tops can go either way, I'm assuming theyre newer being a cool collar set and would have the flange seal. I use standard fel pro exhaust gaskets and have had no issues.
Unlimited jd is offline
Old 09-11-2012 | 08:01 AM
Thanks. The Fel pros I got from Summit last time had very little material covering the header flange can't remember the part# though.
Lil red, do you have a part # for the gaskets you have been using?
badluck is offline
Old 09-11-2012 | 08:59 AM
I will check the box today when I get to the shop.
