-   -   How many Qts. of oil in A 500efi (https://www.offshoreonly.com/forums/general-q/285835-how-many-qts-oil-500efi.html)
bmc 10-03-2012 10:01 AM
Does anyone know how many qts. of oil in a stock 2001 500efi
Pismo10 10-03-2012 10:04 AM
Seven
bmc 10-03-2012 10:08 AM
I am pumping oil out the vents in the valve covers.
F-2 Speedy 10-03-2012 10:18 AM
Sounds like to much crank case pressure, stuck PCV ?
FIXX 10-03-2012 04:46 PM
if the oil is at the full mark on the dip stick then you either bent a exhaust push rod or melted a piston...do a compression test..
