Bilge heating this winter >
Old 10-09-2012 | 09:02 AM
You may want to check out wolverine block heaters if you are dead set on no winterizing. They will heat the block and the block will radiate heat to the rest of the bilge. Fans fored heat will not work well if your boat is on a lift.
looseconnection is offline
Old 10-09-2012 | 09:51 AM
Knot 4 Me's Avatar
Originally Posted by Sydwayz
I'll assume you do not want to winterize with antifreeze because with the boat on a lift, it's difficult to deal with getting muffs on the outdrives, and antifreeze to them. Correct?
Or add a platform to the lift like many do at LOTO. Makes gear lube changes and winterizing a breeze.
Knot 4 Me is offline
