Quick engine cradle clarification?
Do the 496's fit on the same cradle as the 502? Also, as I'm shopping, I see some say sbc/BBC and 1000 lbs...are the sb the same as the bb? Is 1000 lbs enough for a bb to just store?
I am inquiring about the cradles that are real low/close to the ground with 4 wheels...not an engine stand that is used to work on that is about 3 feet off the ground. Thanks! |
the SB & BB from the rear of the block to the motor mount is the same distance, thats where these cradles mount and yes 1000lbs is ok
Thanks...and 496 are the same as well too?
| All times are GMT -5. The time now is 07:38 AM. |
