"Dry" exhaust and Cam Selection Question >
Old 10-19-2012 | 09:45 AM
Default "Dry" exhaust and Cam Selection Question
I'm looking to build some big power small blocks and the cam always seams to be a limitation due to reversion issues and the related limitations on duration.
If I upgrade my exhaust to a 'dry' system with double water jacketed tailpipes, I assume the reversion issue is eliminated completely? Exhaust is a BIG investment.
I can get some headers with big tubes to let big heads breath using a big cam in this scenario?! I am shooting for 600hp so these little 427 cid small blocks are gonna need to breath.
The cam the builder usually uses to produce 610hp in this engine is as follows:
VALVE LIFT WITH 1.5 ROCKERS : INT .580 / EXT .600
DURATION IN DEGREES : ADVERTISED - INT .300 / EXT .506
DURATION @0.050" : INT .253/ EXT .258
LOBE SEPARATION ANGLE : 110º
Thanks for any advice.
Tom
ttrm007 is offline
Old 10-19-2012 | 09:52 AM
with dry exhaust you can use any cam you want,reversion does not happen with dry exhaust.
mike tkach is offline
Old 10-19-2012 | 11:42 AM
Default Thanks - Dry = Good
Maybe a dumb question, but why doesn't everyone run jacketed, dry exhaust?
Disadvantages?
ttrm007 is offline
Old 10-19-2012 | 12:55 PM
zt260's Avatar
Disadvantages?
NOISE...
Without great mufflers I could blow your eardrums out in about 10 seconds.
zt260 is offline
Old 10-19-2012 | 03:05 PM
Default Perfect!
Originally Posted by zt260
NOISE...
Well, that settles it then. Dry it is!
ttrm007 is offline
Old 10-19-2012 | 03:32 PM
zt260's Avatar
Good Choice!
LOL
zt260 is offline
Old 10-19-2012 | 05:21 PM
That is funny.
charliem is offline
Old 10-19-2012 | 05:29 PM
Tom
I do love those cam specs though, she is gonna be one ANGRY sounding lady if you go with it.
Are you going with an LS7 or what are you doing?
Captain YARRR is offline
Old 10-19-2012 | 08:52 PM
Default Small block strokers
427 cube dart shp blocks, pro 1 alum heads, etc... Pretty economical way to put some solid HP numbers in this boat. Should be pushing 1200! I've had small block Chevy hot rods all my life so am doing what the boat is set up for and what I know best (just adding cubes).
ttrm007 is offline
Old 10-20-2012 | 04:51 PM
Sounds like a killer setup! I'm assuming the 230cc Pro 1 heads? Any idea's on carb? HP950's?
If it were mine I would go Lightning Marine Dry Jacketed headers or Stainless Marine Dry Tails if your going manifolds.
Both should not have a problem with any size cam and should let them breathe when you need it.
Loud is Good!!!!
Ryan00TJ is offline
