1996 7.4 problem solved >
Old 10-26-2012 | 11:30 AM
Default 1996 7.4 problem solved
Thanks to all that help me with these problems with my motor its was a bad pickup coil that i bought from mercruiser it had a faulty connection where it connects the white wire to the coil , so it goes to show that not all new parts are always 100 percent, i can say now i know how to use a volt meter and test lite , Much Thanks to you all I appericate it . Now going to go fishing
jimmie is offline
Old 10-26-2012 | 04:36 PM
28Eliminator's Avatar
Catch a big one, or least catch a buzz. Glad you got it figured out finally. It really sucks swapping parts for hours on end to find out one of your new parts is bad out of the box.
28Eliminator is offline
Old 10-27-2012 | 01:03 AM
I have a question i set the timing at the spec in the book 8 degrees before top dead center and the motor idles 800 rpm and their is on adjustment left on the throttle its the butterflys are all the way closed but if I set the timming at like 4 degrees before top dead center it idles right at 650 rpm and runs just as good can i leave it at the or does it need to be right at 8 degrees btdc
jimmie is offline
