1996 7.4 mpi Timing question >
Old 10-27-2012 | 02:33 PM
Default 1996 7.4 mpi Timing question
Again thanks again for all the help with getting my motor to get spark its now fixed and running great but i have a question about the timing I set the timing by the manuel at 8 degrees before top dear center runs great but it idle at 800 rpm and the book says to idle it at 650-700 but their is no linkage adjustiment left , the butterflys are closed , but i noticed if I set the timing at 4 degrees before top dead center it runs fine and idles at 650 rpm is this acceptable or will it harm my motor , Thanks James
jimmie is offline
Old 10-27-2012 | 03:28 PM
racinfever's Avatar
Did you ground the timing module when setting timing?
racinfever is offline
Old 10-27-2012 | 05:49 PM
Default Yes back to neg on battery and pos to pos in battery
Yes black to neg and pos to pos on battery
jimmie is offline
Old 10-27-2012 | 06:18 PM
now i wondering what do you mean by timing moduel ?
jimmie is offline
Old 10-27-2012 | 06:54 PM
Here is a link to a cool little tool that will put the mpi into base timing mode
http://www.rinda.com/marine/marine.htm
I thing it can be done with a jumper wire as well I'll see if I can find one of the threads and post it for you
Z06vette1 is offline
Old 10-27-2012 | 07:12 PM
Default mercuriser
cool i appericate it
jimmie is offline
Old 10-27-2012 | 07:50 PM
You have to jump the A and B pins in the data plug. That will put the ecm in base timing mode. Then, set the timing to 8 deg. BTDC. You can either use the Merc timing jumper, a small piece of wire, or a paperclip. I use the paperclip since I can never find the Merc tool in the shop when I need it. Once you put the jumper in, you may need to rev the engine up to 1500 rpm or so to get the timing to stabilize.
Eddie
Young Performance is offline
Old 10-27-2012 | 09:12 PM
Default Timing
cool thanks man
jimmie is offline
Old 10-29-2012 | 04:41 PM
Part Number...805747A2 , TIMING TOOL, EFI
1800rpm
$12 bucks from Bam Marine
Back4More is offline
Old 10-29-2012 | 05:51 PM
1800rpm
Paper clip free
tunertech is offline
